1999 GMC Yukon
GADDIS02
  • 14 POSTS
Engine Performance problem
1999 GMC Yukon Engine Size unknown Two Wheel Drive Automatic 214000 miles
why does my yukon jerks on me when i go up a hill, i already change my oxygen sensor, (that what to auto man told to change), but it didnt help.
Mar 10, 2008 at 8:44 AM
RHALL77
  • 3,361 POSTS
did he say you were gettig a lean codition, was it a lean code? If that is the case it sounds like a vacuum leak with the intake. Or it could simply be a tune up. Try to spray water on the plug wire and see if it miss fires. If that is ok check the distrubitor cap for corrison and the same with the rotor. Let me know what happends.
Mar 10, 2008 at 9:43 AM
GADDIS02
  • 14 POSTS
[quote:11696f87d2="rhall77"]did he say you were gettig a lean codition, was it a lean code? If that is the case it sounds like a vacuum leak with the intake. Or it could simply be a tune up. Try to spray water on the plug wire and see if it miss fires. If that is ok check the distrubitor cap for corrison and the same with the rotor. Let me know what happends.[/quote:11696f87d2]
he just told me that the oxygen sensor where bad. i going to get it a tune up this friday.
Mar 11, 2008 at 8:39 AM
MASTERTECHTIM
  • 4,750 POSTS
99 percent of the time a jerking or bucking going up a hill is cured by performing a complete tune up, cap rotor and wires and spark plugs. let us know how you make out.
Mar 11, 2008 at 10:03 AM
GADDIS02
  • 14 POSTS
[quote:d0aa1df6e5="mastertechtim"]99 percent of the time a jerking or bucking going up a hill is cured by performing a complete tune up, cap rotor and wires and spark plugs. let us know how you make out.[/quote:d0aa1df6e5]
I WILL, I WILL WRITE BACK THIS WEEKEND.
Mar 11, 2008 at 12:38 PM
GADDIS02
  • 14 POSTS
[quote:7495941989="gaddis02"][quote:7495941989="mastertechtim"]99 percent of the time a jerking or bucking going up a hill is cured by performing a complete tune up, cap rotor and wires and spark plugs. let us know how you make out.[/quote:7495941989]
I WILL, I WILL WRITE BACK THIS WEEKEND.[/quote:7495941989]
I JUST CHECK MY OIL IN MY YUKON, I JUST GOT A OIL CHANGE JUST LIKE 2 WEEKS AGO. I HAD TO HAD SOME MORE OIL IN IT, IT DOES NOT LEAK OR SMOKE. WHAT IS WRONG WITH IT?
Mar 13, 2008 at 4:01 PM
MASTERTECHTIM
  • 4,750 POSTS
it probably was not filled properly when the oil change was done. monitor it again in two weeks and get back to us
Mar 14, 2008 at 10:29 AM
GADDIS02
  • 14 POSTS
[quote="gaddis02"][quote:da998cdbef="mastertechtim"]99 percent of the time a jerking or bucking going up a hill is cured by performing a complete tune up, cap rotor and wires and spark plugs. let us know how you make out.[/quote:da998cdbef]
Got a tune up today, drove with no problems no jerking or bucking, thank you for yall help.
Mar 19, 2008 at 8:41 AM
GADDIS02
  • 14 POSTS
Mar 19, 2008 at 1:03 PM
GADDIS02
  • 14 POSTS
[quote:01d752793a="mastertechtim"]it probably was not filled properly when the oil change was done. monitor it again in two weeks and get back to us[/quote:01d752793a]
my oil is low again, what should i do?
stephen
Mar 23, 2008 at 9:50 AM
MASTERTECHTIM
  • 4,750 POSTS
how low? do you see any leaks under vehicle at all? is it still running good?
Mar 23, 2008 at 10:41 AM
GADDIS02
  • 14 POSTS
[quote:6baa451046="mastertechtim"]how low? do you see any leaks under vehicle at all? is it still running good?[/quote:6baa451046]
just under the operation range line. their is no leaks that i see i park in the same spot at work and their is no oil on the ground . it runs great! also i had a wreck in it, i hit a deer, i already replace the parts for it. i think i might have to go to higher mileage oil, it have 215,00 mile on it. im using valvoline 10-30
Mar 23, 2008 at 1:20 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like a plan
Mar 24, 2008 at 2:37 AM
GADDIS02
  • 14 POSTS
[quote:7eba1cf5ce="mastertechtim"]sounds like a plan[/quote:7eba1cf5ce]
I will try that.
stephen
Mar 24, 2008 at 8:35 AM
