1998 GMC Yukon water pump
89,000 MILES • V8 • 4WD • AUTOMATIC
SANDOVAL503
hi i just got a 1998 gmc yukon. i had it in the shop getting some ignition work done and they told me i had some coolant leaks. they said it was the pump and the manifold intake gasgets.i wanted to get anotherb opinion , how can i check that the gasgets are leaking? Ive driven the yesterdy and today and i didnt see the coolant level drop,
Feb 6, 2008 at 1:10 PM
BMRFIXIT
  • 19,053 POSTS
[quote:1cecf29509="sandoval503"]Other Category problem
1998 GMC Yukon V8 Four Wheel Drive Automatic 89000 miles
hi i just got a 1998 gmc yukon. i had it in the shop getting some ignition work done and they told me i had some coolant leaks. they said it was the pump and the manifold intake gasgets.i wanted to get anotherb opinion , how can i check that the gasgets are leaking? Ive driven the yesterdy and today and i didnt see the coolant level drop,[/quote:1cecf29509]
Manifold and water pump is a common thing to fail
so you can’t deny their claim with out
having the system pressure check
after you park the truck and turn it off do you have any leak under it ?
Feb 6, 2008 at 1:26 PM
