1998 GMC Yukon Check engine light came on.
CVFC1216
  • 1998 GMC YUKON
  • V8
  • 4WD
  • 210,000 MILES
How do I reset the ECU on my 1998 GMC yukon. Earlier today I pulled the stock air intake off to clean it and I disconnected the two wires that were connected to it to do so. One went to the Mass air sensor the other im not sure what its called. I turned the truck on a little while after and I noticed the check engine light came on. Any ideas what it may be. One my friends said try resetting the ECU first
Thursday, July 30th, 2009 AT 2:25 PM
BUDDYCRAIGG
  • 2,262 POSTS
You can clear the codes with a scanning tool
https://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
or if the problem has gone away, the light will go out on it's own after you have driven it enough.
but the code will remain in memory.
Thursday, July 30th, 2009 AT 3:01 PM
