Do you think I should replace the fuel pump, and how big of a job is it?
Thanks a bunch!
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have pump performance assessed if the noise is new or changing, rather than replacing the pump from sound alone. Investigate the interior-light battery drain separately.
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. HELLA: Injection-valve diagnosis https://www.hella.com/techworld/en/technical/sensors-and-actuators/injection-nozzle/ General pressure-test background; use the installed fuel system specifications.
1997 Suburban humming sound from rear
A newly purchased 1997 Suburban had a hum near the fuel tank only while the engine ran. Removing the fuel-pump relay stopped both the sound and engine. Other owners described similar noises; the owner planned maintenance and also reported interior lights draining the battery.
Reported outcome: No pump test or repair was reported.
Other vehicles' noisy but functioning pumps do not establish that this pump is healthy. Relay removal also stopped the engine, limiting that observation.
