1997 GMC Yukon Day Time Running Light Module Location?
GSCHALL
  • 10 POSTS
Electrical problem
1997 GMC Yukon V8 Four Wheel Drive
Does anyoine know where to locate the Day Time Running Light Module. I have not found it but it could be the problem with the no headlight issue I have been dealing with.
Any help would be apprectiated Thank you.
Jun 9, 2009 at 11:42 AM
SERVICE WRITER
  • 9,123 POSTS
Left side of dash, taped to panel wiring harness.
Jun 9, 2009 at 11:55 AM
GSCHALL
  • 10 POSTS
I will check under the left part of the dash and see if I can find the panel harness. Thanks again
gschall
Jun 9, 2009 at 4:07 PM
SERVICE WRITER
  • 9,123 POSTS
Sometimes the electrical component locator leaves a lot to the imagination. Your best bet is to see what it looks like beforehand if you are unfamiliar with it.
Jun 9, 2009 at 10:29 PM
GSCHALL
  • 10 POSTS
Thank you for your help. I did find it, the module was inside of a black plastic box hanging from some wiring harness. However, that was not the problem. I may have to try the high beam switch next.
Jun 16, 2009 at 9:40 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the next most loical spot to test.
https://images.2carpros.com/forum/automotive_pictures/30961_yuk_2.jpg
Jun 16, 2009 at 1:35 PM
GSCHALL
  • 10 POSTS
Thanks for all of your help, I finally had to change out the Signal switch wand that did solve the problem. I know three other Tahoe or Yukon owners that had to do the same thing over the past three months. These must be a problem in general. Thanks GM.
Anyway I got mine at a junk yard but of course its a gamble, since you moght be getting another problem, however, I got mine for free and swapped the broken flasher button out with my original one that worked fine. All things are good once again.
Thank you to everyone that helped me with advise.
gschall
Jun 23, 2009 at 12:18 PM
SERVICE WRITER
  • 9,123 POSTS
Very cool...That is a pricy switch. You did good!
Jun 23, 2009 at 2:23 PM
