1996 GMC Yukon Ticking
1996 GMC YUKON
126,241 MILES • V8 • 4WD • AUTOMATIC
CVSA78
  • 9 POSTS
I started the truck this morning (really cold) and the truck made the normal ticking. It usually goes away about 3 seconds after startup. But this time it stayed. Checked the oil. Fine.
40 LBS of oil pressure the ticking is from both sides of the motor on top (valvle cover). Do you think it's a lazy lifter? Would Marvel Mystery oil help?
Thx
Jan 22, 2008 at 10:08 AM
MASTERTECHTIM
  • 4,750 POSTS
yeah lazy lifter. try mystery oil, that should buy you some time. **also check your intake gaskets, sometimes they leak coolant internally and can cause lifters to take a long time to pump up. are you losing coolant but dont see a leak?
Jan 22, 2008 at 10:12 AM
CVSA78
  • 9 POSTS
I checked the coolant and all is fine, no sludge, and the overflow is full and the rad is full. Just an ungodly ticking.
Jan 22, 2008 at 10:29 AM
MASTERTECHTIM
  • 4,750 POSTS
are you positive its not an exhaust leak. these are notorious for leaking at the y pipe where it bolts to manifold. the bolts will be tight but the pipe is loose, and sounds exactly like a lifter. check that before you go insane
Jan 22, 2008 at 10:35 AM
CVSA78
  • 9 POSTS
I'll check it out tommorw.
Thx
Jan 22, 2008 at 11:57 AM
CVSA78
  • 9 POSTS
I finally looked a little deeper. Checked the exhaust/manifold/y pipe connections - all is tight.
Drained oil - looked ok - no metal, added 1 qt marvel mystery oil and new filter- No change
Removed serpentine belt to eliminate tensioner - no change.
The tick seems to come from both sides of the motor just under the valve covers?
I hooked up an external oil pressure guage - 55 - 60 lbs @ idle cold.
I just think the upper part of the engine is not getting oil.
Any ideas?
Jan 25, 2008 at 10:25 AM
MASTERTECHTIM
  • 4,750 POSTS
i have replaced alot of those sets of lifters and it always fixed the problem. let us know
Jan 27, 2008 at 3:44 AM
CVSA78
  • 9 POSTS
[quote:c6b0193427="mastertechtim"]i have replaced alot of those sets of lifters and it always fixed the problem. let us know[/quote:c6b0193427]
Pulled the intake and valve covers and 3 colapsed lifters. Waiting for parts, should have them tuesday.
Mike
Jan 27, 2008 at 3:52 AM
CVSA78
  • 9 POSTS
I have never seen roller tip rockers in a truck from the factory. Any Ideas?
Jan 30, 2008 at 12:14 PM
MASTERTECHTIM
  • 4,750 POSTS
roller lifters is what they use. just to be sure, you did check to see that the camshaft lobes are not worn out.**most likely they are not** but double check
Jan 30, 2008 at 12:32 PM
CVSA78
  • 9 POSTS
Thanks, I checked the cam and all is fine. Got everything back together and sounds a lot better. I going to let it cool down and adjust the valves again.
Thank You for all your help
Mike
:D
Feb 1, 2008 at 9:42 PM
CVSA78
  • 9 POSTS
Readjusted everything and it runs like a sewing machine. Nice and quote. Thanks Again for your help
Feb 6, 2008 at 12:06 PM
