1996 GMC Yukon overheating (gauge reads in red)
1996 GMC YUKON
249,000 MILES • V8 • 2WD • AUTOMATIC
THYRAG
this was an intermittant problem but now is happening every time runs. Gauge indicates overheating, check gauge light comes on after only 6 or 8 miles. When slow down the gauge will decrease to normal in less than one minute, but goes back up if speed increased again.
radiator and water pump replaced about 2 years ago, changed to the "red coolant" which turned into brown goo and had to be replaced (went back to old green coolant) and the whole system flushed, neglected to flush tubing between resivoir and radiator, so had to add fluid/coolant to radiator (gurgling). Since Feb of this year we have flushed radiator, replaced thermostat, replaced the fan cluch, replaced temp cooling sensor and replaced the instrument cluster, with no improvement. I may be in denial due to the milage, but have taken very good care of mechanical with regular service and care at a GMC certified dealership which now has lost dealer but still has the certified mechanics.
May 15, 2010 at 10:07 PM
HMAC300
  • 48,601 POSTS
due to the age and mileage on this vehicle i'd pressure check it and i'd have to say if heats up that quick i'd go for a thermostate or intake or head gasket... even a new thermostat can be bad. Also check the radiator for cold spots after it heats up. If it has cold spots it shouldn't the radiator should be the same temp all accross and over it. make sure to do this with the engine OFF.
May 26, 2010 at 2:32 AM
