I need to find the location fo the heater valve vacumm line.
Nov 3, 2008 at 4:47 PM
BMRFIXIT
✓ASE Certified Mechanic
Heater and temperature is controlled by cable and not vacuum
what is it that you have a problem with
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 6, 2008 at 12:23 PM
YUKONREMS
MEMBER
The heater valve IS vacuum actuated. It is a replacement for the same exact thing that was leaking. The in dash control is only electrical connections behind the dash. The control has rear barn door defroster and a/c.
I can not find the vacuum source to control the valve.
Thanks, Russ
Nov 6, 2008 at 6:57 PM
