1995 GMC Yukon Ignition Switch
265,000 MILES • V8 • 2WD • AUTOMATIC
SJPKON
My GMC Yukon will not crank unless i put the gear in neutral and then crank it. and if i put it back in park it wont come out of park with out shutting the engine off and starting the entire cranking sequence over which means i gotta put it back in neutral and then crank the truck up. What is wrong with my ignition and transmission.
Jan 12, 2010 at 2:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
this is caused by a faulty Neutral / Park Safety Position Switch. It is not a tranny or ignition fault, just a bad safety switch.
Jan 13, 2010 at 1:11 AM
SJPKON
bluelightnin6 thanks for the response. Would you by chance happen to know where this switch is located on one of these trucks?
Jan 13, 2010 at 2:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should be located on the steering column, under the dash.
Jan 13, 2010 at 3:57 AM
SJPKON
Thanks again bluelightnin6. You are the best.
Jan 13, 2010 at 6:28 AM
