1994 GMC Yukon wheel lock
196,000 MILES • V8 • 4WD • AUTOMATIC
1970HOTWHEELS
Firsts thing in the morning,when i start moving.The right frt wheel locks up,even if i haven't touched the brakes.I step on the brakes & a pop is felt n the body of the truck.Then it will move a couple of feet & then lock up again.Must step on the brake again & pop felt then it is fine all day.Or unless the vehicle sits for a couple of hours.
Both front brake calipers & hoses have been replaced & mastercylinder.Brakes have been bled numerous times.
Jan 7, 2010 at 8:46 AM
DOCFIXIT
  • 18,828 POSTS
Does this happen in Reverse ? Have CV joints been checked?
Jan 8, 2010 at 5:03 AM
1970HOTWHEELS
no it doesn't happen in rev's only forward.plus axles are ok.rings & sensors ok.no codes present.
Jan 8, 2010 at 8:38 AM
DOCFIXIT
  • 18,828 POSTS
Call me crazy but are wheel lugs torqued down? Rotor seated on hub?
Jan 9, 2010 at 5:48 AM
