1994 GMC Yukon fuel pump
JAMES STEPHEN
  • 1994 GMC YUKON
Engine Mechanical problem
1994 GMC Yukon V8 Four Wheel Drive Automatic 200k miles
can you give me any tips about easiest way to remove fueltank
Saturday, December 26th, 2009 AT 8:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi James,
The only easy way, is to make sure the tank is pretty much empty. Other than that there really isn't an easy way. The only thing I would suggest is that a few hours prior to doing is to spray all bolts with a good rust penetrating lube. Also if using a floor jack would also have a piece of 1/2" or thicker plywood about 14" x 14" so that the head of the jack doesn't damage the tank.
Saturday, December 26th, 2009 AT 9:23 AM
