1992 GMC Van NO BACK UP LIGHTS
205,840 MILES • V8 • 2WD • AUTOMATIC
MTRDUDE
  • 51 POSTS
I have a 92 GMC Vandura with 205,840 miles (VIN#2GDGG31K6N4506417) that has no backup lights. I've checked the harness going to the lights & there is no power to them. I traced the wire back but can't find where it is supposed to receive power/be powered from or how the circuit is supposed to work.
Dec 10, 2008 at 11:45 PM
  • 75,988 POSTS
Sir-The back-up light switch is located at the base of the steering column-unplug it use a small jumper wire and jump the connector-is the light On ? If so replace the switch.
Dec 11, 2008 at 12:11 AM
