2003 GMC Truck error code P0171
2003 GMC TRUCK
70,000 MILES • V8 • 4WD • AUTOMATIC
JLHERM
What can I do to fix the error code P0171. When idleing it is running rough, and when driving there is power loss. When you let off the gas the motor stalls.
Dec 26, 2009 at 11:03 PM
MICKEY-D
  • 304 POSTS
I believe that code is a lean system code for bank one on a V8 GMC engine. Go to your local parts store, and they will scan it for you and tell you the problem. they usually do it for free, hoping you will buy the needed parts from them. Check for pulled loose wiring to the injectors, also plugged or dirty fuel filter.
Dec 31, 2009 at 12:08 PM
