2002 GMC Truck catalytic converter
18,000 MILES • V8 • 4WD • AUTOMATIC
BTSCOTT1
My catalytic converter is clogged so I removed the pre and post converter oxygen sensors, unbolted it from the exhaust and manifolds but there is no way this thing is coming out. Do I have to remove the oil pan and heat shield too? Doesn't seem to give enough clearance even if it is removed. What am I missing?
Thanks,
Brian
Nov 13, 2008 at 1:42 AM
  • 110,246 POSTS
Brian:
You may have to unbolt the trans from the cross member and carefully lift it with a jack to get the clearance needed.
Let me know if this helps.
Dec 10, 2008 at 5:51 AM
