2001 GMC Truck 2001 GMC 2500HD suspension lift from a Duram
2001 GMC TRUCK
163,000 MILES • V8 • 4WD • AUTOMATIC
DEVINIA
  • 16 POSTS
There is a suspension lift from a 2005 duramax 2500HD that is willing to trade for a stock heighth suspension. I have a 2001 GMC 2500HD with the 6.0 Vortec with the stock suspension. I was wondering of how interchangeable the suspension components are and if it would be possible to trade straight accross or what would need to be bought? also how do you install these?
Thank you,
Devin
Mar 8, 2010 at 7:53 AM
2CARPRO JACK
  • 11,533 POSTS
I have installed an RCD lift on a 1/2 ton that year.You may want to get the instructions on how to install it, the frame has to be cut where the front diff mounts,and a plate welded in. You have to drill holes for the new torsion bar rear mount. Its not really that hard, but to put the stock stuff back is where the problem maybe if the mount was cut off.Other than that it is basically just bolt in stuff.The Duramax truck may have a heavier torsion bar than your gas engine truck.Be sure to keep the correct torsion bars with the right trucks.
Mar 8, 2010 at 10:57 AM
