1998 GMC Truck shifting problems
235,000 MILES • V8 • 4WD • AUTOMATIC
SHEILARAE
truck shifts ok when cold. When warmed up it will not go into overdrive or gear one. I have already changed the electrical harness and it is not the ignition switch, what else should I be checking :(
Oct 18, 2010 at 11:29 PM
HMAC300
  • 48,601 POSTS
take it toa trans shopwhere they can scan it to seeif any codes are set. It could be somethingelectricalor the trans bad itself.
Nov 2, 2010 at 8:09 AM
