1998 GMC Truck Distributor timing adjustment
1998 GMC TRUCK
158,000 MILES • V8 • 4WD • AUTOMATIC
HVFD7014
I just put a new motor in this truck, with a RV Cam. Runs, but timing is off. My mechanic friend is having trouble getting it right on timing. Exactly how do you set the timing on a 1998 GMC 2500 4X4 Vortect 350?
Jun 6, 2009 at 6:01 AM
MICKEY-D
  • 304 POSTS
You need to get the specs for that specific engine. You can't just assume you can time it the same as the stock engine. Cam timing could be different, and that can affect the ignition timing. You may have to use a light and do total timing at say 3500 or 4000 RPMs.
Dec 31, 2009 at 4:17 PM
