1998 GMC Truck brake lights
1998 GMC TRUCK
CW95TA
Electrical problem
1998 GMC Truck V8 Four Wheel Drive Automatic
brake lights only come on when emergency flashers are activated. changed pedal switch with no luck. cargo brake light works. all relays working and intact. i've done everything i know of
Dec 21, 2009 at 9:50 PM
PEAR69
  • CAR REPAIR CONTRIBUTOR
  • 1,482 POSTS
Your brake lights are wired through the turn / hazzard signal switch. This is a common issue - and it indicates that your switch is failing. Replace the entire switch unit...Be sure to dissable the airbag - if equiped - by removing the airbag fuse when working on this switch...
Dec 22, 2009 at 2:55 AM
