1997 GMC Truck rotor removal
90,000 MILES • V8 • 4WD • AUTOMATIC
TOCOKID
i have 97 gmc seirra 3500 dually 4x4, i would like to know how to remove the old rotors,do i have to remove the axle bolt to get them off?
Jun 3, 2010 at 11:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
take all the bolts/nuts off of the axle and smack it with a hammer so it pops out. take the axle out and you will see a very large nut. if you don't have the socket for it and you probably won't, you can take a chisel and nick the edge to back it off. take that out then there will be a large washer, take that off, and then an inner nut like the outer. take that off and the drum should come off.
Jun 3, 2010 at 2:37 PM
