1997 GMC Truck GMC 7500 top kick 2 1/2 ton
JENIA
1997 GMC Truck V12
When the brake pedal pushed, the power streering stop working? any suggestions
Feb 20, 2010 at 5:01 AM
MICKEY-D
  • 304 POSTS
Check you power steering fluid, add if necessary, then tighten the power steering pump belt. Your power brakes operate off your power steering pump. If the belt is loose, or the fluid is low, one or the other will not work.
mickey-d
Feb 23, 2010 at 3:48 AM
