when backing up on a steep incline or too quickly in reverse, the truck will pop out of gear and grind. i replaced all bearings in rear differential and the pinion bearing. ring gear appears to be fine. u-joints are new too. is this a transmission problem?
Nov 23, 2008 at 1:18 AM
