1997 GMC Truck disengages from gear in reverse
1997 GMC TRUCK
184,000 MILES • V8 • 4WD • AUTOMATIC
CHARLIE5
when backing up on a steep incline or too quickly in reverse, the truck will pop out of gear and grind. i replaced all bearings in rear differential and the pinion bearing. ring gear appears to be fine. u-joints are new too. is this a transmission problem?
Nov 23, 2008 at 1:18 AM
MICKEY-D
  • 304 POSTS
It sounds like a weak, or bad engine mount, or maybe a trans mount, allowing the linkage to pull the trans out of reverse.
Jan 7, 2010 at 6:17 AM
