1996 GMC Truck engine problems
JUNIORPEREZ
Engine Performance problem
1996 GMC Truck V8 Two Wheel Drive Automatic
truck does wanna start i have checked fuel pump and changed it out and have also checked fuel filter and have checked my spark plugs and battery is good
Dec 3, 2009 at 2:17 PM
MICKEY-D
  • 304 POSTS
Need more info. Does it crank over, and if it does crank, does it have spark to the plus when it's cranking?? If so, then it is a fuel problem. Give it a squirt of starting fluid while cranking it over, and if it starts, check fuel pump pressure, and fuel pressure regulator.
Dec 31, 2009 at 1:04 PM
