1996 GMC Truck
GLENN SEVERANCE
Electrical problem
1996 GMC Truck 6 cyl Four Wheel Drive Automatic
the vehicle had codes for multiple missfire mass airflow sensor,and couple other codes.when starting vehicle put it into gear it would die start it again it would take of sometimes or die,once it was going down the road it was fine than all of a suden it lost power than died now it wont start,replaced cranksensor,camsensor,distributor,coil,ignition module,egr valve,but it has no spark at all please help.thanks glenn
Dec 26, 2008 at 5:26 AM
DONALD5354
[quote:4b76ef5370="glenn severance"]Electrical problem
the vehicle had codes for multiple missfire mass airflow sensor,and couple other codes.when starting vehicle put it into gear it would die start it again it would take of sometimes or die,once it was going down the road it was fine than all of a suden it lost power than died now it wont start,replaced cranksensor,camsensor,distributor,coil,ignition module,egr valve,but it has no spark at all please help.thanks glenn[/quote:4b76ef5370]
Feb 22, 2009 at 7:43 AM
