1995 GMC Truck the truck has no power
1995 GMC TRUCK
GWINDSOR
Engine Performance problem
1995 GMC Truck V8 Two Wheel Drive Automatic
the truck loose power between 1500-2200 rpm
if the timimg is set at 0. right now the timimg is set at 12 after we disconnect the wire to set timing that the only way we can get it to run good.
it has a new distributor,cap,rotor,wire,plugs,coil,fuel pump,egr,tps,02,iac,pvc,coolant temp sensor.
the only thing else i can thing of is the computer
Jun 12, 2010 at 5:49 AM
MMPRINCE4000
  • 8,548 POSTS
Mechanical timing should be 8-10 degrees, not 0.
Jun 16, 2010 at 12:20 AM
