1995 GMC Truck Engine dies then immediately restarts
212,000 MILES • V8 • 4WD • MANUAL
DBURCH51
  • 7 POSTS
Just recently my truck will die while driving down the road and then start itself right back up. It dies like it would if you shut the key off, there is no backfire, slow dieing of the engine or sputter at all it just goes dead then comes right back. I read on the internet that some people found the crankshaft position sensor to be the problem. Do you think that is it? Or what else could it be, and do you know where the crankshaft position sensor is on this truck?
Mar 18, 2009 at 4:02 AM
  • 75,988 POSTS
Could be the CPS its located on the bottom front engine near the crank pulley
Mar 21, 2009 at 2:55 PM
