1995 GMC Truck 4x4 front end
197,000 MILES • V8 • 4WD • AUTOMATIC
HELDINGFARMS
have 1995 gmc 3500 w 6.5 diesel. The four wheel drive doesn't engage. actuator goes in and out dropped front axle out and spacer washer had fell out of place put back together so it would be locked in four wheel drive worked well.Took out of four wheel drive will not engage again. put silicone around spacer last time anything else i can try or why does that spacer not stay in place?
Jan 11, 2009 at 7:18 AM
JAMES W.
  • 2,394 POSTS
Not to appear ignorant, but what "spacer" is giving you the problem? I have been all over the exploded view if the BW4470 T-case and can't find one that is accessible from the outside. Please advise.
Jan 12, 2009 at 8:16 AM
HELDINGFARMS
The spacer is in the pumpkin on the end of the right axle there is some lip on the axle but not enough to hold the washer in place I don't know if the lip is wore a little or if the piece broke off
Jan 13, 2009 at 12:40 AM
JAMES W.
  • 2,394 POSTS
I think you you're talking about the thrust washer just inside the case. Do you have, or have access to, a fax #? If so, I will fax a copy of the exploded view and you can point out the part that is giving you the problem. Please advise.
Jan 13, 2009 at 6:08 AM
