1994 GMC Truck 4wd will not engage
CAMAROHONEY
Drive Train Axles Bearings problem
1994 GMC Truck V8 Four Wheel Drive Automatic
Just had tranny rebulit now 4wd wont engage. Replaced actuator but no change. Checked fuse it was burnt so I put a new one in and it burnt immediatley. The 4wd worked fine before the tranny rebuild. Help me please there is snow in the forecast!! Is putting a higher amp fuse than the recomended 25amp a bad idea??
Jan 20, 2009 at 2:49 PM
MIKE H R
  • 3,094 POSTS
check the wiring to see if there is a pinched wire that is shorting out. With the fuse blowing that quick that is where I would look first.
Jan 21, 2009 at 1:47 AM
