1993 GMC Truck Pops out of fourth gear
128,000 MILES • 6 CYL • 2WD • MANUAL
TXBWJ
Hi, I have a 93 gmc sierra stepside, five speed. It is difficult to get into fourth gear, and then pops out of gear. All of the other gears work just fine. Could this be a slave cylinder problem?
I do notice a whine sort of like a power steering pump going out, but the power steering pump is fine and the noise goes away once shifted to third gear, any ideas.
Oct 12, 2009 at 2:35 AM
MICKEY-D
  • 304 POSTS
I think you have got a bad synchronizer, and probably a badly worn 4th gear. The whine that you hear is probably a bearing noise. You are going to need to pull out and rebuild your trans.
Dec 31, 2009 at 2:31 PM
