1992 GMC Truck radio not working
237,000 MILES • V8 • 2WD • AUTOMATIC
#1LAWRENCE
radio not working after working on cigarette lighter
Apr 23, 2009 at 12:23 AM
MIKE H R
  • 3,094 POSTS
check wiring where you worked on cig lighter to make sure the wire is not shorting out. then check the fuses, you may have blown a fuse while working on lighter. check the wire to the radio a possibility that one of the wires going to the radio has been pulled loose.
Apr 23, 2009 at 1:43 AM
