i need to find out how much tranny fluid a 700 gm tranny needs. i need the total amount of gallons or ounces needed.please
Feb 13, 2010 at 2:25 PM
HMAC300
✓Experienced Mechanic
unless you are changing the fluid try to find a manual that is close to that and look under technical specs. it will give it to you. But if you are changing all thefluid then it's somewhere around 11 quarts. maybe 12.
