1990 GMC Truck Torque converter
102,000 MILES • V8 • 2WD • AUTOMATIC
JOHNBOY27
I just installed the turbo 400 onto my truck, I forgot to put fluid in the torque converter. The truck will not in gauge the transmission. Is this because I didn't put fluid in the torque converter?
Jun 17, 2009 at 6:05 PM
BMRFIXIT
  • 19,053 POSTS
torque converter uses a lot of ATF fluid and if empty tranny will not function or move the truck
have to fill the converter
do not run it long as you may damage converter
good luck
Jun 17, 2009 at 11:25 PM
