1990 GMC Truck Taillights
1990 GMC TRUCK
190,000 MILES • V8 • 4WD • AUTOMATIC
BECHAROF
The taillights on this vehicle will not come on when the headlights are turned on.
-Brake lights work
-turn signals work
-reverse lights work
-hazards work
All lights are bright
The vehicle has an alarm on it- when activated/ deactivated- all taillight bulbs flash as they should
all bulbs work, fuses seem fine, cleaned and reconnected ground
at the same time this problem started- the interior dash lights went out- dont know if its relevant
turn signal switch, nuetral safety switch replaced about a year ago
help please- thanks
Sep 13, 2009 at 4:25 PM
MICKEY-D
  • 304 POSTS
Did you check the fuses? Tail and dash cluster lights are generally on the same circuit.
Dec 31, 2009 at 2:50 PM
