1990 GMC Truck Pressure and Temp Recommendations
GPHILLIPS123
Air Conditioning problem
1990 GMC Truck V8 Two Wheel Drive Automatic
Whatr would the high and low side pressures and temperatures read for an R12 system on this vehicle
Oct 28, 2010 at 3:24 AM
BMRFIXIT
  • 19,053 POSTS
I don't know of a set pressure that they should be at,but this is what I remember on the subject
they should be within 10 PSI from each other with engine off ,using high and low pressure gauge to check
the compressor should cycle on at (41-51 PSI)and cycle off at (20-28 psi) so if your system is running with pressure (20-28 PSI )you are low and need to add and check
or maybe you are looking for this www.
chillers.com/PT%20charts%20for%20refrigerants.htm
Oct 28, 2010 at 9:53 AM
  • 75,988 POSTS
Hi gphillips123, Welcome to 2carpros and TY forthe donation
I used this as a guide-see below
LOW pressure gauge: Normal when its between 25-40 psi
High pressure gauge: Normal at 200 to 225
Note: Anything over will cause the system toovercharge
I don't have the temperature readings-Sorry
Oct 28, 2010 at 10:14 AM
