1990 GMC Truck clutch
NMAN1990CA
Transmission problem
1990 GMC Truck V8 Four Wheel Drive Manual
hi, i have a 1990 gmc k1500 350ci motor with a manual transmission. the clutch on it will not worked iv checked the master clutch cylinder and the line all the way down to and includin the slave cylinder and there all in workin order with no leaks. i have tried to bleed the line an it wont work, i have taken the master clutch cylinder off and there is lots of presure in the cylinder its self just none at the petal...please help i dont know what to do...thanks in advance.
Jul 12, 2010 at 5:20 AM
DR LOOT
  • 2,311 POSTS
I guess I'm not getting the whole story, slave cylinders are very hard to bleed, I can run you through the procedure if you respond.
Jul 20, 2010 at 6:00 PM
