1984 GMC Truck NO SPARK
DENALI951
Electrical problem
1984 GMC Truck V8 Four Wheel Drive Automatic
ENGINE DIED WHILE TRAVELING, AFTER REPLACING THE DISTRIBUTOR(NEW),COIL(NEW) AND VERIFING THAT THERE IS 12V AVAILABLE TO THE DISTRIBUTOR, THERE IS STILL NO SPARK.
May 15, 2010 at 1:54 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
May 15, 2010 at 2:20 PM
