1979 GMC Truck low pressure side of air conditioning
1979 GMC TRUCK
20,000 MILES • V8 • 4WD • AUTOMATIC
LINEDOG
the aluminum line where the orofice tube goes is bent and I can't get the new screen in properly, could this line be cut so I can straighten the line out and clamp it with a rubber hose, or is there to much pressure on the low pressure side to do this? its the small line from the evaporator .
Jul 19, 2009 at 1:48 AM
MICKEY-D
  • 304 POSTS
Way too much pressure ! The small line is the High Side, the large line is the Low Side. Try using assorted size 1/4 drive deep sockets and tapping them lightly to get the bend out little by little. if you can't do it, you'll have to get another line.
Dec 31, 2009 at 3:19 PM
