1999 GMC Suburban Removing front rotors
1999 GMC SUBURBAN
RICH6161
Brakes problem
1999 GMC Suburban V8 Four Wheel Drive Automatic
How do I remove the front rotors? Removed pads and calipers already. Need to turn front rotors....???
thanks
Jan 1, 2009 at 12:30 PM
BRIAN 1
  • 1,030 POSTS
hit inbetween the wheel studs with a hammer,these are floating rotors.also spray wd40 around where the rotor sits on the hub,the rotors usually freeze onto the hub.post back with any other questions.
Jan 1, 2009 at 12:58 PM
