1999 GMC Suburban NO REAR Tail Lights/Brake/Turn/Flasher li
1999 GMC SUBURBAN
12,000 MILES • V8 • 4WD • AUTOMATIC
KENNYROYJOHN
  • 9 POSTS
I am not good at all with electrical testing procedures, but all my rear lights went out. I have noticed for some time a clicking sound when I press the brake pedal. How can I tell if it is not the bulbs, or fuses which I checked, if it is the Turn signal Flasher, or the turn signal switch, or the brake light circuit which runs thru the turn signal switch, or the brake Light switch. I know this is a long post, but if you r experienced I will correspond with you thru email if it is OK.
Jan 24, 2010 at 10:29 AM
Check the ground circuit at G415 at left frame rail behind bumper if okay time to open up the turn/hazard switch and investigate
Those back lights share the same ground and if its gone -nothing will come on back there
Good Luck
Jan 24, 2010 at 10:45 AM
