1999 GMC Suburban engine hesitation
190,000 MILES • V8 • 2WD • AUTOMATIC
WALKER2
why does my engine hesitate and sound like its choking and about to kill when i press gas
Jun 19, 2010 at 2:49 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 19, 2010 at 9:20 PM
