The 4 carrier bolts should be about 55-65 ft lbs. The pinion or yoke as you call it is tighten until you get 15inch lbs of drag on a new bearing or 5 inch lbs of drag on an old bearing. Your ntu would be tight and not any particular torque.
SPONSORED LINKS
Friday, June 4th, 2010 AT 7:27 PM
