1997 GMC Suburban REVERS LIGHT DOSN'T WORK
1997 GMC SUBURBAN
300,000 MILES • V8 • 4WD • AUTOMATIC
SULTANS
I have 2 problems
1- while car neutral, and the Engine running, the RPM gose up and down till the Engine turned off.
2- the revers light dosn't work?
May 30, 2010 at 11:44 PM
  • 31,937 POSTS
Hi there, for the idle problem have the idle control motor checked and check for any vacuum leaks, a scan for any unresolved fault codes will also help. For the reverse lights, check fuse and switch on transmission,
Mark (mhpautos)
May 30, 2010 at 11:49 PM
