1997 GMC Suburban leak between the master cylinder and the
1997 GMC SUBURBAN
JSTRALEY
Brakes problem
1997 GMC Suburban V8 Four Wheel Drive Automatic
i have a gmc k2500 and I have a leak between the master cylinder and the hydrobooster is there a o ring or a seal the i can replace. it is leaking power steering fluid not break fluid.
Jun 6, 2010 at 12:34 PM
The brake master cylinder is leaking-your best bet is replace it-brake problems are dangerous
Jun 6, 2010 at 12:38 PM
  • 31,937 POSTS
The master cylinder rear seal is leaking, normally this is due to wear or corrosion in the bore, it will be cheaper to fit a new master cyl as ally cylinders must be re sleeved and not honed out as the older cast cylinders.
mark (mhpautos)
