1997 GMC Suburban Coolant temperature spike
125,000 MILES • V8 • 4WD • AUTOMATIC
MARK46
Frequently, the coolant temperature spikes to near overheating, but then quickly returns to normal temperature. A friend says that there is likely an air lock? or some air trapped in the system. Is that likely? How do to correct it? This has been going on for several months.
Also, very recently, the air blown into the car suddenly was not heated. I believe the computer light came on, probably around the same time. My thinking is to replace the thermostat and extract the code at the auto parts store and go from there, but maybe you can give some diagnostic tips to someone without a lot of experience.
Nov 11, 2008 at 6:16 AM
  • 31,937 POSTS
Hi there,
Replace the thermostat and get the radiator cleaned & flow tested as it may be partly blocked, check the cooling fan is working correctly as well.
mark (mhpautos)
Nov 11, 2008 at 3:23 PM
URB0123
  • 6 POSTS
When my vehicles get low on coolant, they will often stop heating the cabin air. You could be low on coolant, or as suggested, have a massive air bubble/air lock in the system.
Jan 28, 2009 at 11:37 AM
