I replaced the power brake booster and now my transmission won't shift out of park.
Aug 8, 2009 at 2:12 PM
✓Experienced Mechanic
Could be something you accidentally disconnect under the dash-double check wiring connectors if okay-Check the shift interlock control system-Is your brake lights working if not check the brake switch
