1996 GMC Suburban turn signals
MDEDE
Electrical problem
1996 GMC Suburban V8 Four Wheel Drive Automatic
I have a 1996 GMC Suburban with turn signal problems. Both the signals and the reverse lights are not working. The rear lights will flash with the brake pedal depressed and I move the turn signal up and down. The hazard lights work on all 4 corners.
It does and I’ve checked the following-
Checked fuses
Checked relay
Disconnected trailer lights
Checked light bulbs
Any other things I can try?
May 8, 2010 at 10:49 AM
  • 75,988 POSTS
Test the turn and hazard switch.
May 8, 2010 at 12:00 PM
