1996 GMC Suburban Ignition fuse
1996 GMC SUBURBAN
ASCHERER
Electrical problem
1996 GMC Suburban Four Wheel Drive Automatic 200000 miles
This is a diesel engine. I keep blowing the ignition fuse. What could be the cause? Will I need to replace the ignition system? Or could it be a simpler fix?
Jul 6, 2009 at 12:14 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Hello, I looked at info for the 6.5 diesel. The only ignition fuse I found was ign E-- 10 amp fuse. Supplies voltage to the ac relay--fuel pump balance module--fuel pump balance relay. I'd unplug the circuits one at a time, try to see which one is causing the problem.
Jul 6, 2009 at 1:46 PM
ASCHERER
The fuse I am blowing is a 40 amp fuse. It blows out as soon as you turn the key. We even tried a 60 amp fuse once, that did no better. This fuse is in the fuse box under the hood, not inside the cab. Maybe not necessarily an ignition fuse???
Jul 6, 2009 at 1:53 PM
JDL
  • 16,098 POSTS
I did find a maxi fuse 40 amp, under hood fuse box. Supplies voltage to ignition switch as well as the starter relay. Does it blow at the on or crank position? I hate to see you blow all your fuses, but, you need to protect the circuit. You can pull the starter relay, see if the fuse still blows? Not conclusive, but a start.
Jul 6, 2009 at 3:52 PM
