1996 GMC Suburban 4wheel drive
DIEGOBOYSS
Transmission problem
1996 GMC Suburban V8 Four Wheel Drive Automatic 160k miles
The four wheel drive won't engage when I press the button to convert, it just blinks. What is wrong with my Suburban?
Jan 6, 2009 at 5:28 PM
  • 110,248 POSTS
Hi:
There is a 4wd actuator on the side of the transfer case that determined 4wd. You need to check if it's getting power when you switch to 4wd. If it is, remove it and check for operation. It may need replaced.
Feb 17, 2009 at 11:01 AM
