1995 GMC Suburban White smoke from exhaust
1995 GMC SUBURBAN
30,000 MILES • V8 • 4WD • AUTOMATIC
HEAVYCHEVYGUY
I have been having a bit of an issue with the heater core hose fitting above the water pump, it leaks from time 2 time. I figured the o ring may have went bad. Now just the other day i went to start my truck and got a sound like the starter slapping against the flex plate/fly wheel and the truck would not start. Thinking i had an issue with my stater I tried a few more times and it finally started but the first few stroke were weak it seemed as if the motor wanted to stall. Then I began to get thick white clouds from my dual exhaust pipes. I immediately ran to checked the gauge to identify if the truck was over heating, but it wasnt. I felt for moisture at the exhaust and it felt dry. I also checked the oil dip stick after letting the truck cool off for about 30 min. and the oil was dark not milky. I also changed the fuel filter because I thought I pumped some bad fuel (watered down). What do you think?
Jun 1, 2009 at 12:23 AM
MMPRINCE4000
  • 8,548 POSTS
Clouds of white smoke would indicate a head gasket or intake gasket.
First perform a compression test, if OK then perform a cooling system pressure test.
If compression is down, DO NOT pressure test the cooling system. You will have to replace the head gaskets.
Jun 1, 2009 at 1:00 AM
