1995 GMC Suburban how to adjust timing
1995 GMC SUBURBAN
120,000 MILES • V8 • 4WD • AUTOMATIC
SCOTT208
My timing is too high and I am wondering how to adjust it. I am looking for the specifications. There is not a sticker under my hood.
Thanks
Feb 5, 2010 at 10:42 PM
BIGRAYMARTIN
I have asked a similar question, which may be helpful... my question is: "does this gmc have EST - electronic spark timing?" If it does, then you must unplug the EST in the relay box on the firewall before you use a timing light to view the "teeth" and the timing mark on the pulley, using a strobe light. Best done by a mechanic, amateurs are often injured by fan blades and belts.
Feb 7, 2010 at 11:43 AM
